what should my fuel psi be for a 6bolt swap?
95eagletalontsiawd
61
Mar 11, 2012
Norwood, Missouri
i have a 6bolt swaped in my 2g with 95 ecu and i was tuning it (dsmlink v2.5) and came across my fuel psi is 43.5 sould it be set at 1g fuel pressure of 37psi, its also got a walbro 255 fuel pump and fic 950cc injectors. and will i have to retune it if i have to switch fuel pressures,
Thanks
Yup, like everyone says 2g. The reason is you match the fuel pressure to whatever the ECU is expecting (so if you happened to have a 1g ECU you'd set it to match what a 1g ECU was expecting). (I mention all this in case somebody was wondering WHY the answer was 2g).
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
