what should i do?
TSI_TILLIDIE
Banned Member
31
Dec 23, 2010
chicago, Illinois
i was wondering if i will be able to turn up the boost to 12 13psi my supporting mods are safc 1, new clutch, removed boost solenoid, fmic
no i wanna turn it up i just didnt want to damage anything because i dont have a data logger im getting dsmlink in 30 days
You should be doing boost leak tests as standard maintenance. You'll be safe running 15psi but before using the SAFC and turning the boost up more, get a logger. You won't be able to do too much with the SAFC until you get larger injectors as well. 650s are the max size you want to run on the SAFC BTW.
