What plug to ground? for Base timing!
Froyd79
295
Jul 6, 2003
Altoona, Pennsylvania
The one I thought it was made the starter get crazy! Haynes and Chiltons really dont give a good view and I dont know if its just me or not but the Vfaq was the same way. Is it the suppossed to be 2prong connector but only has 1 pin in it? Roughly 1/2 inch wide 1 inch long? I tried one that was about 1/2 inch long and 1/4 inch wide.
The VFAQ pic is kinda hard to see but the plug should be behind the battery area. Mine was stuffed under the loom and I had a hard time finding it at first. It should also have a plug/cap in it unless someone has removed/lost it. Mine has 1 metal prong and one plastic? pink prong in it. Hope this helps.
