- Thread starter
- #51
atruepretense
- 166
- 1
- Jul 15, 2009
Bethlehem,
Pennsylvania
So, my DSM took a crap on me about 6 months ago. It's been sitting for so long because I kept having problems with it and lost my job at the time, so couldn't afford to fix it. But, as I was driving down the highway, my timing belt decided to skip on the crank almost 180 degrees out, bending every single on of my valves. There were no stripped teeth, no visible belt damage at all. But it was out of time. Then, I replaced everything, mounted the engine all back together, timed it, and started it. Got this horrible tapping noise. I mean a LOUD tap coming from the top end. Took the valve cover and found 4 lifters that weren't holding at all. Changed all the lifters, started the car, same damn noise.
The car is hesitant to accelerate. Can't get it above 3-4k rpm at all. It's idling at like 2k -2.5k rpm. I drained the oil, didn't see any shavings at all. I have no clue what's going on with the block. I'm about to pull the engine and tear it apart to see what it could be. Any chance anyone can give me some ideas on what to check now?
I was thinking checking the balance shaft bearings for some reason. I just am stumped as to what it could be. I mean damn. Not a rod, not lifters, wtf?
Thanks!
Thanks!
