What if it is not a boost leak?
razrman8
1,435
25
Jul 7, 2010
Troy, Missouri
I had a boost leak at my throttle body , fixed it. Also the bov flange gasket was leaking, fixed it for the most part it leaks the slightest of little bit. My injectors were leaking, new seals on that. A repair in the plastic part of the uicp was leaking repaired that. So my question to you guys is, what can it be if it is not a boost leak? I swapped bcs thinking it could be that. Not too much of a difference. In first gear I am getting 6-7 pounds. But I do notice when WOT it slowly rises. And I mean SLOWLY. Itll go to 6-7 then move slow to 8. Does it sound like a leak if its moving slow? What else could it be? I have a brand new type s on its way to my house. Just so I can be sure of no leaks. And I've been wanting it.
Thanks in advance
If you are questioning a leak then you need to do a proper boost leak test. It seems you have the experience to do one and my guess is that you did not perform one after assuming your leaks are fixed. Remember, soapy water is your friend, bubbles are not...kill the bubbles!!!
I did in fact do a test after I sealed the leaks. And went outside and did another one just to be sure because I hate when threads are posted with these kind of problems and no blt is performed . The bov gasket leaks just a tiny tiny bit after I've rtv''d and also I saw that the biss screw is leaking a little. I just couldnt see how those can make that much of a differece. But I've been wrong before. Probably wont be the last time.
A little leak can go a long way. You'll want to get a new o ring or try lubing up the current one if it's still in good condition. If you are going to replace it, a temporary fix is to fill the BISS hole with RTV. Make sure you will be able to remove the RTV before doing that however.
Also note that 1st gear shouldn't be used to judge your boost. There is not enough load on the motor to allow for much boost to occur. If you want to check your PSI level, do it in 3rd gear.
Good point. I was doing that to see if it was different gears to verify the information I am providing. 3rd gear also get about 7-8 pounds. I have began to wonder about my wastegate flapper maybe not sealing correctly but is there any way of knowing? I have a e316g a few days ago that I want to put in but I do not want the same problems so I am trying to track down the culprit
I'm made a video for you liquidx, just so we are on the same page :thumb: its almost done uploading
**bov flange gasket
A video from my phone | United States | By Keenan Willis (thorcr80)
The best way to check is by taking the turbine housing off and visually inspecting the flapper and the seat with the actuator both attached and removed.
However with the actuator rod removed, you can check to see if there if the flapper will close any further. If it's fully shut against the seat and the actuator rod keeps it in that location (attach the rod) then it's possible there are some significant cracks at the seat where the flapper seals out the exhaust.
Cracks are common and will develop over time of constant heat cycling. If this is turbo related then the 16g will fix the issues assuming there isn't anything else.
Did you get the wastegate ported on the 16g to prevent boost creep?
Not to barge in but that leak at the bov flange came on really quick. What kind of pressure is your line regulated at, and how much boost is inside the intake when the leak starts to bubble? Seems to me its at a very low boost (2~3psi). If its that low then that "small" leak @ 7psi will be even larger. That with the biss screw leak could cause you to not boost more then what your seeing. It also could be covering up another leak that don't show up until higher boost levels.
I see. Never came across me like that. I could try redoing it. But I do have the new type s on its way. Oh well Im going to try again and see. Thanks
What LIQUiDx is saying sounds pretty logical. I would pull the turbo off and inspect the housing for cracks. Wouldnt hurt to check your manifold as well..
Hmm. Well the thing with pulling the turbo is if I was pulling it,I want to be putting the 16g on. I don't know though. I mean it would be the right thing to do
First initial bubble is ~5psi
Nothing is wrong with putting it on. I just dont want to put it on and still have the problem. I guess I will never know unless I do. I have a ss oil line for it and and adapter for the oil feed on the turbo so it wont take as long.
Im just trying my best to eliminate everything that it could be first.
When you do a blt do you spray the soapy water over all of the piping? You could have small holes in the inter cooler, pipes, etc. When I do a blt I SOAK the entire intake track/manifold. I found a ton of small leaks all over the place when I had the stock pipes. They wouldn't allow me to hit more then 11psi. And to fix the leaking Bov flange I just use a small bead of rtv. I could never get the gasket to seal without it...
This may be a turbo/waste gate issue in the end but fixing all boost leaks will improve everything about the car. Installing a 16g wont hurt or help a boost leak. If you have a turbo and want to put it on you can.
Pre-turbo exhaust leak, turbine housing leak, faulty/improperly installed, faulty/improperly installed boost controller, boost gauge, faulty turbo/wastegate.
my BISS seems to have a tiny leak on it but why in the world wouldnt it screw out :confused: ive tried a magnet, ive tried a needle nose, ive tried screaming at it. the thing just spins and spins and i cant pull it...
Not running a boost controller . Boost gauge checks out. Manifold is good far as I can see.. rest leaves turbo..
Screw it out as far as you can and do another boost leak test, it will pop out:thumb:
+1 that will most likely do it :thumb:
Did you actually TEST for a pre-turbo exhaust leak or are you just eyeballing it?
Color your exhaust white so you can see it coming through your leaky manifold.
  • For sale 4G63 Frontline Fabrication V2 Billet Valve Cover
    Frontline Fabrication V2 Billet Valve Cover $750 + shipping & paypal fees* swivel AN fittings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
