Should this be happening if not what does it mean
Your talking about the little pin hole in the fitting in the mbc? How many psi are you running, and how many psi are you checking for leaks at?
It's normal for there to be a little air coming from the bleed hole on the mbc, thats how it regulates boost.
BCS does not equal MBC. No it is not normal, you probably need a new BCS.
So air shouldn't come through the top hose on bcs when doing blt? How does it work then ? Thank you spawnedx
Your right, I saw BC and imagined my own M. Disregard me, sorry :coy:
It's alright simple mistake
What do you mean by come through, clarify a bit better. Like its leaking going into the bcs, between the hose and the nipple. Or when its not powered, its leaking through the bcs..
Sorry. When I pump air into the turbo via BLT, there is the line on the bottom nipple of the bcs that goes to the nipple on the t25 and t's off to the wastegate. Then the top nipple of the bcs has a hose that goes runs to the injen intake. Should air be be coming out of the top line that runs to intake in blt?
Coming out of the top nipple rather. The hose isnt leaking.
Okay just to make sure I understand the BCS line that goes to the intake, basically a recirculation of the air it let's bypass to hit it's 12 PSI mark, is pushing air, or when you do the BLT and spray water and soap on it, it's bubbling out, because a BLT only covers air escaping a sealed system.
You're talking about the port that goes to the intake pipe, correct? Air should come through the top port, into the intake pipe when doing the BLT. When there's no power going to the BCS, it's open, bleeding the air so that it doesn't actuate the wastegate actuator.
This is exactly the answer i was looking for.. I didnt know that if it should have been circulating with the car off
Thank you. I apologise fot the comlication, was having trouble trying to properly describe my question.
Now that I know it should do you have an insight on this thread of mine
http://www.dsmtuners.com/forums/tur...osting-situation-questions-please-helllp.html
I had injector seal leaks like crazy. Fixed 3 of them cause i dropped one.. But ill use this sealant stuff we have to fix tomoro. Also the biss screw should leak a little air shouldnt it ?
I will do a complete checkdown of it tomoro
Spawnedx .. Great video reccomendation. I will have to remember this one :thumb:
BISS screw should not leak at all.
Alrighty. It sounds like it to me also. But I just couldn't think of where they would be coming from. Everytime I fail to remember the soapy water. Now, if the biss screw is in fact leaking, do i just get a new o-ring for it ?
