What does 7cm2 housing mean?
4gfun
Supporting VIP
2,012
56
Dec 10, 2007
Ask Me, Virginia
Like the subject says, I am not sure what 7cm2 means. I have the hot side of my compressor sitting here with part number 78-11830 which is supposed to be 7cm2.
I was just wondering if I could take my dial calipers and measure something that is "7cm2".
Thanks
Which of these pics does that measurement refer to if applicable?
You can't measure any thing that is 7cm2 cause the two is "squared" meaning area. You would have to have some sweet calipers for that.
Picture 3 post 1.If you look straight down from the inlet on the housing.The wg hole should not be visable.
Porting opens that up.
As well in the same picture of the inlet.You can clearly see its been modified.The stock casting is supposed to be all smoothe..As you can see, yours is not all smoothe like that.
