stace
- 86
- 16
- May 27, 2008
Belleville,
ON, Canada
Ok, I bought a non running 90 awd tsi for $500. This is what I got...
Drive train seems still ok, everything rolls and the suspension looks new.
I new the belt had skipped and the valves were bent, pistons were fine..according to 3 mechanics. But while I was cleaning it up, I found the head had already had the head bolt holes drilled out. So I'm guessing its on it second broken timing belt.
Oh well, I was expecting this anyway.
Now I have the turbo off and I found new problems. I have 2 stock turbo manifolds and 2 14b's...The manifolds all have cracks, one mabye salvagable but I will ###### weld up a tube mani anyway.
Both turbos have cracks running around the outside of the turbine housing, right near the mitsi symble. I assume this is normal. Should I bother using either of these turbos?
I do have 2 chrysler t3 42/48s' and 1 ford turbocoupe t3 a/r60comp, a/r 63turb. they were byproducts of my turbo saturn project. Would any of these garrett turboe's work on a 4g63?
worry about some more boost. them turbos will work but buy the time you get oil feed,drains o2 housing and a t-3 manifold you could just buy a new 16g. that will proform better with out a tune compaired to the other turbos.
