what do I need for a n/t throttle body swap?
1990AWD
Supporting VIP
8,541
26
Apr 27, 2009
Langham, SK, Canada
I'm going to be swapping the throttle body on my '90 GSR-4 for a 91+' n/t throttle body and use a FAIV bypass plate.
Will all I need to rebuild the tb the shaft seals, biss screw, tb gaskets, and isc gasket? Also, I can't find where it shows how to rewire it; can someone give me a link?
Thanks.
Parts to rebuild:
-shaft seals
-shaft screws (not required, but should be replaced)
-BISS screw
-BISS o-ring
-FIAV gasket
-ISC o-ring
http://www.dsmtuners.com/forums/articles-intake-exhaust/301466-1990-swap-91-94-throttle-body.html
Thanks Brian.
Are there only the two shaft seals on the throttle body? Also, where does one find those shaft screws; I can't find them from any online vendor.
As far as wiring, the tech article just says to put in a new connector, but doesn't say which wire to sauter to which wire. Do you have a schematic or are they just done by colors?
Sorry for asking so many questions; thanks though.
    • Sdcryan1
