What did you do to your DSM today?
unwrapped my Evo III Big 16g today! set it in my passenger seat to take it home, so far no gain.
I made this (yesterday):
attachment.php
See more here: http://www.dsmtuners.com/forums/bolt-tech/395597-flow-same-air-filter-intercooler.html
today i pulled and painted the break lines. the brake booster and relocated the brake fluid cylinder
today i ordered new valves, springs, retainers, lifters, and seals. um finally got my block on the engine stand and started to take everything off it. my timing belt broke a few weeks ago and am starting my build!
Fixed cas wiring harness with maft that thing has to go once link gets installed. Fixed wideband, boost, and oil pressure gauges.
removed my power steering.
haven't driven it much yet, but I don't know if I like having manual steering...
I opened the hood and stared at the empty space where a turbo should be, and debated on where I should install the EGT sensor that I just bought to hopefully prevent melting turbine shafts in the future.
I also welded a nut to the O2 housing/downpipe flange, and then bitched at my g/f because my car isn't running yet.
Stay tuned. :D
Polished my thermostat housing and ate coffee ice cream while watching porn.
i went into my garage i yelled at it cause its missing all the clutch bolts and all the other bolts starter alt bolts :'(
decided how im gonna eliminate the back seat and fit 2 lms 18's in it with 2 sundown saz-4500d's.
just kidding im only goin with 1 10'' but im figuring out a false floor to make the rear hatch flush cause i absolutely hate that damn hump, i wanna cut it out and weld in some flat metal.
Not today I guess but yesterday, no two days ago, LOL. I disconnected the BOV recirculation tube, plugged the hole in the intake, and now my Greddy blows to the atmosphere :)
Please tell me you're not running a properly setup blowthru so I can call you an idiot.
I'm not.. yet. And I'm not keeping it this way until I have everything to do that. But I did do it this way for a bit so thought I'd share.
I hope your either running link or maf t.
Sent from my HERO200 using Tapatalk
I'm going to run EvoScan with Speed Density. But I need to get some funds first for the cable and AFR before I tune.
