What did you do to your DSM today?
better ants than a roach infestation. And not the roaches that you smoke but the ones that crawl.
lowered my asking price to 2700$ and still cant get any intrest in it :\
Rewired the fuel pump and wired NLTS (untested as of now :().
Bonus: I have never seen my volt meter read over 13.9 until now at idle, its now at 14.2-14.4, Whooo!
Finally got the other side of my garage organized enough to pull my gsx in to sit next to my spyder. Hopefully I will get the gsx parted out soon unless the doubt bug gets me again and I decide to fix it and keep it. Eh who knows. Maybe an automatic gsx would be a fun daily driver. Ah see there's that dam bug again.
What started as a simple maintenence day turned into another FP bi*** session...
Changed T-Case & Rear Diff fluids
Rotated tired while it was up on jackstands
Messed with the JMF exhaust manifold heat shield mounting 'soultion' (if you can even call it that)... ended up fabricating new mounting points and a bracket for it
While fabricating a mounting solution & staring at the FP manifold, I noticed another crack :mad: This is my second FP manifold that has cracked on me (and in the exact same place as the first one)! WTF??!! Guess I'll go back to an Evo 3 now :notgood:
Changed my brakes, rotated my tires, change brake fluid and fix one broken wheel stud on my spyder.
And have yet to go see my baby these past two weeks, the eagle talon which is parked at my parents place.
i installed a walbro 255, did the fuel pump rewire and installed a tomei fuel pressure regulator to the firewall day accomplished :hellyeah:
I put in an evo 1 oil cap, new 5spd eprom, and a new fender..ALso got it running, but theres sum kind od drai on my battery, cause it wouldn't start when i shut it off..And also its idle surging now, I gotta figure that out..
finished wiring the drivers side wiring harness and started the passenger side harness.
Having clutch dragging issues. Bled the clutch today, no change. Next thing I know I'm pulling pieces of metal out of the rubber inspection boot next to the clutch slave. Gotta order a clutch kit and flywheel.
