b00st3d
- 468
- 378
- Jan 13, 2005
Yukon,
Oklahoma
I put a good end clutch pack in the Spyder and got to take it for a spin. This car is a blast to drive, Auto, AWD and the 6152.
Don't feel bad, pretty sure my clutch just went out, sob just won't go into any gear unless the vehicle ignition is off. I'll find out soon enough.I'm just buried under some biiig sucks..![]()
I think thats just a clutch hydraulic...Don't feel bad, pretty sure my clutch just went out, sob just won't go into any gear unless the vehicle ignition is off. I'll find out soon enough.
Hopefully. I'll probably just end up having a new clutch kit put in, flywheel, throw bearing, etc. I figure I might as well since the trans (are we still calling them trans, or are they now called gender neutral shifting boxes?) will have to be dropped for the new clutch to be installed. What's going on with yours?I think thats just a clutch hydraulic...
Once my clutch hydraulic was punctured all oil leaked... was a funny drive to home without clutch.Hopefully. I'll probably just end up having a new clutch kit put in, flywheel, throw bearing, etc. I figure I might as well since the trans (are we still calling them trans, or are they now called gender neutral shifting boxes?) will have to be dropped for the new clutch to be installed. What's going on with yours?
Picked up some hardware from Lowe's automotive to finish installing brake booster and clutch master cylinder; following the clutch pedal lever replacement.I just repaired my clutch pedal assy because of this. The car would only go into gear on jack stands with the engine running, or while the car was off and on the ground. Got everything apart and found the TOB races and ball bearings welded, TOB clip just fell out in pieces, chunks of the TOB fell down, trans oil was black, glazed flywheel and clutch assemblies.Don't feel bad, pretty sure my clutch just went out, sob just won't go into any gear unless the vehicle ignition is off. I'll find out soon enough.
What was the reasoning fo going this route as oppossed to a conventional off the shelf big brake kit? Just curious. Fad, response, clearances, etc?Finally finished up installing a set of JDM Galant knuckles, SPC UCAs, and a @STM tuned Wilwood brake kit. Now I just need to bleed everything and bed in the brake pads.
After weighing everything I dropped 10lbs per corner of unsprung weight and, since I went to a JDM Galant knuckle, can install Evo Brembos (or similar) in the future if I want to do more than just drag racing.You must be logged in to view this image or video.
The simplest reason was that I wanted to upgrade my stock brakes to stop from 125mph+ trap speeds without increasing the cars unsprung weight.What was the reasoning fo going this route as oppossed to a conventional off the shelf big brake kit? Just curious. Fad, response, clearances, etc?
Replaced the headlights, finally got the turn signals working correctly. The project is coming along nicely.
I just ordered them, they arrived 3 days ago. Thanks for the compliment. Got pics of your beast?Were these something you had saved for awhile, or did you buy them? Because those are like a brand new version of my current headlights and they look incredible honestly. I think they match the 2GA's perfectly. Way better than the OEM ones.
