v8s_are_slow
- 2,825
- 280
- Sep 30, 2002
Panama City,
Florida
okay so a welded diff, spool, and vce pretty much all lock in all 4 tires correct? if this is correct, then could one assume that you're saying none of these should be used on the street and that they'd all chirp the tires going around corners? just that a welded diff can't be changed back to stock? but overall, those 3 things do exactly the same thing when it comes to locking in the tires correct?
and a quaife, kazz, and cusco are the best way to go if ya don't mind forking out the bucks cause they're streetable and good for the track at the same time? although you'd still need to upgrade to a 4 spider gear for strength?
and the only thing the 4 spider gear does is give you more strength. am i missing anything?
i'd rather put up with wheel chirp and the longer time it'd take to park than to deal with fwd. but i'll try not to get off topic....
as is anything other than a 1/8th mile track
..........thx
