JusMX141
Moderator
- 15,147
- 1,289
- Dec 13, 2005
Greensburg,
Pennsylvania
From what I've found in the past, shimming the wastegate may help get the initial spike to be higher, but once the gate opens the weak actuator still has difficulty pulling it back shut again so it still results in a big drop in boost.
The best choice if you want to keep the turbo internally-gated, especially if you have a 34mm flapper, is to upgrade the actuator to one with a higher spring pressure. When Mitsubishi designed the 16G they never imagined a bunch of gearheads would be trying to run 30psi on the stock internal wastegate system.
