Water Temp Gauge Sender in the A/C sensor hole?
bigemrich
519
Jun 1, 2004
Butler, Wisconsin
I removed my A/C a while back and I was wondering if I could use the coolant temperature switch (A/C) on the thermostat cover to run my Water Temp Gauge sender? Anyone know?
--Kyle :talon:
By the way, Im not asking if it will fit so much as I am wondering if it will hurt me pulling the A/C sensor after I removed the A/C
--Kyle :talon:
Well in the haynes it lists three sensors...Coolant Temp Sending unit, coolant temp sensor (ECM) and coolant temp sensor (A/C)...Now I am assuming that with the A/C removed I would have no use for the A/C sensor, but would that work as a tap for water temp?
--Kyle :talon:
