water temp sensor in thermostat housing?
2G95tsi
Dec 3, 2007
El Centro, California
i have a new water temp gauge and i dont know where to tap the thermostat housing to place the new sensor someone... does anyone have a picture of where to do this?
You can use the factory hole if you want. Both the factory and aftermarket threads should be 1/8NPT. If you still want to keep the factory gauge working, then any area underneath the thermostat should be OK, as long as you have a room to work. I did this on my car and it works just fine.
