wastegate Problem..HELP
eric91gst
163
May 30, 2006
Sylvaina, Ohio
OK so I got my exhaust housing off and was going to start porting and then I noticed that there is a little space showing through where the flapper sits onto the wastegate hole. I also noticed that part of my exhaust housing is cracked inside. I know the flapper should totally cover that hole but would it be fine to just put it back onto the car?
-thanks
It might lose a little boost, but other than that it should be fine. If the crack penetrates completely, then no, you should replace. If not, then bolt up IMO.
- I am going to be running a 14b. And the circle part of the wastegate is not totally covered all the way by the flapper when the flapper is closed. There is a little space in the top left corner of the circle that you can see through when the flapper is shut. So yes there is actually a space all the way through, but its not really a crack. It must have shifted a little bit when the other parts cracked, and now it doesnt have a full closed seal like it should. Ill try and get pictures up If i can if that will help u guys.
-thanks
I can see light all the way through looking at the flapper that doesnt totally cover the wastegate hole, from the downpipe side. (with the downpipe off)
well I just ported the hell out of it, so I think that will make up for some of that turbo lag, if there is any.
-thanks everyone for answring my questions and helping me out.
