wastegate flapper. GONE
If you switched to external you would have to weld your internal shut. Unless you run the wastegate after the hotside which doesnt really make sense but sone people do it. Lol if you didn't weld it you would never create boost.
You can weld a new flapper to the arm.
I would take this oppertunitity to upgrade to a 34mm flapper(you might be able to find it for cheaper):
Forced Performance Turbochargers: FP 34mm Wastegate Flapper
Also take the time to port the wastegate hole, and inlet of the turbo.
http://www.dsmtuners.com/forums/tur...-doing-about-their-td05-wg.html#post151910447
I would argue running the external off the o2 housing makes more sense (I run it off the o2 housing), not in the case of custom tubular manifold.
Lol I'm was thinking he was swotching to a tubular. Ya not off the stock o2. I would upgrade to a tubular and go external. Once you run external you will never want internal again LOL
