Wastegate Flapper Install
DSM4me44
752
Jul 2, 2004
Medina, Ohio
I have had a boost creep problem ever since i installed the 14b. I ported the turbo and o2 housing. I want to port the wastegate flapper hole but i need a new flapper then. Can anyone tell me where i can get a bigger flapper and how to install it. Thanks!
You can port the wastegate hole area a little larger than stock before you need a larger wastegate but if you want to port it a lot. Then you can buy a 34mm flapper from www.slowboyracing.com I did this a few years ago and it pretty much cured my creep, you can port that hole a lot larger after the install. The old one is really hard to get off though. I probably just didnt have the right tools. I went at it with a dremel for an hour or so and got it off. The new one is just put in the same spot then you have to hammer the top down a bit to make it larger. Then it won't be able to slide off but it should still be able to pivot a little to create a good seal against the new hole. good luck
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
