16G Wastegate Flapper
2bclutch
203
Jan 10, 2006
Richardson, Texas
I searched the forums for this and didn't really find the answer I was looking for. I pulled my turbo and was looking at the wastegate flapper. Two things, The first thing is I can't pull it open just by using my finger, shouldn't it be able to open easier than that? and Two, both ports are black as hell, I'm guessing that's from the previous owner running too rich?
Your wastegate isn't supposed to be movable with finger pressure since it needs to resist the air that naturally flows to it as it boosts. Also, the blackness is indeed from running rich. If the turbo was run on a motor with a stock fuel setup and A/F ratio, that would certainly explain the carbon buildup. Most cars that run on the lean side have a tan color on the turbine blades and those that have run race gas will be covered with white deposits from lead.
Sounds like you're OK to me,
Andy
Yeah was running rich for a bit with the AFCII since I have the 550cc injectors and am not running high boost atm until I get the nice 16G boost leak issue fixed. Also the guy who had the car before me had the MBC Tee'd off the BOV which is retarded. Does anyone know if there's a place that makes J-Pipes with a nipple on them for the MBC?
You don't need to buy one with a nipple on it already. You can simply tap the j-pipe and do it yourself. If you don't have a tap and die set, you can drill a slightly undersized hole and the nipple will still thread into it. Just be careful and keep the nipple straight when installing it.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
