Wally ?
DSM_munky_man
1,128
6
Sep 20, 2010
Tulsa, Oklahoma
Hey guys, I tried searching for something relavant but nothing ever comes up the way I type it i guess. My question is what is the hp that the single 255 needs help? I have 2 installed, but think it may be overkill for my goals. I am (in the end) wanting around 500 horses or so on e85. will a single 255 be enough or should I keep the 2?
Ok but he wants to do it easily. Without the lengthy seat time and many more busted trannys as a consequence ;) So he should stick with the fuel pump setup he has and know that he will have plenty of fuel if he wants to up the boost with a healthy enough turbo to actually see his goal realistically. He did mention 500whp here. And he IS running a 16g.
The single wally setup would be enough for that. But it's plus $50 to you and minus the time taking the pump out AND minus the time money put into installing it that way in the first place. . . I don't see why this is a big discussion. If you're going to do it, you can see your goal with one intank. But you're doing away with all the work you already put into a dual pump setup. . . So I tend to keep my work IN my setup, instead of taking it out by doing more work for $50.
I'm not saying he should downgrade everything. I just always see people make large dollar mods to cars, end up no faster for all the work, and sell/ part the car.
Are you running e85 already? If so, getting knock at low boost is next to impossible.
For the money you have wrapped up in your setup, you could already be running low 12's. The formula is out there. 16g, e85, injectors, 1 wally, clutch, and a 3" exhaust. My car trapped 107 with the only mods being a walbro, 16g, 750cc injectors, and i burned a chip. Full stock exhaust, and intake.
No e85 yet. Waitin on a few things before I do. And as of right now I am being limited by knock on running anything more on current. So I am tuning that out to see where it gets me.
And I didnt realize it was going to be this big of a deal asking this question LOL. I am leaving it in, but was just wondering what a single wally would be able to handle just in case I did happen to need a quick buck for bills or something that would be the easiest thing to get rid of since I already had one.
keep it in there. You may be able to make 500 with one you may not. Why take the chance if you already have it. Once you start maxing out the single walbro it's hard to control the AFs
the more the marrier. as long as you have a good regulator doing its job keep the 2 pumps and save the hassel for the future or incase 1 happens to fail have a backup
