Walbro 255 Fuel Pump
unplugme71
185
3
Apr 21, 2011
Central, New Jersey
Is it okay to replace the stock fuel pump with the Walbro 255 without any other modifications done to the car? I know the fuel filter is probably bad, and since i'm going to be in that area, I was thinking just swapping everything out.
I do have plans to run a bigger turbo w/ supporting mods soon, so I will need to have it installed anyway.
If there's anything else I need to go along with the fuel pump, let me know.
Thanks!
You may or may not need an AFPR; some people see fuel over-run during idle, some don't. At the very least, it's a good investment to give you full control over base fuel pressure.
You'll also want to rewire the fuel pump even if you stay with a stock one.
Check out this page if you haven't seen it yet, and be sure to use the site's search function. Just about any question you can possibly ask has been answered many times in the past. ;)
Awesome, I'll go ahead and order the fuel pump and fuel pressure regulator. Any brands you recommend for the FPR?
@motozachl - I was referring to the filter on the fuel pump :)
