Ultimate 1G & 2G DSM Brass Shifter Pivot/Cable/Base Bushings Set (28pcs)
I would like to add some 1990 shifter info to this thread. On the '90, it has a Shift Stop Bushing also. I believe it was a rubber or maybe a plastic piece from the factory and I used rubber o-rings on my shifter. I believe this is an issue with bending or breaking shift fork tabs in the transmissions so when that piece wears out, you can "over" shift the transmission. See my pictures and you will notice this difference. Other than that, the 1990 shifter uses all 6 bushings the same size for you 90 owners. Maybe @Gsx-Dude will see what I am saying and be able to offer his version of a 1990 specific kit. Honestly, I think a piece of rubber vacuum hose would probably work for the shift stop peg cover. It really makes the shifter have a cushion at the end of the throw and not over throw the shift. Sorry for the clutter.
EDIT.....Post #9 shows a 1g shifter handle and it looks like it has the same shift stop post that I am showing but I don't know if it was solid metal or a smaller shaft like my 1990 has. I HAVE verified that the pink, thick o-ring does work, I don't know how long it would last, maybe a stack of 2 or 3 of them would be perfect.
Also, the 1990s have 4 hold down bolts to the floorpan.
Marty
Thank you for your input!
I'm still looking fo a 90 shifter assembly so I can start getting a set for these too.
In the meantime I managed to make the other part you mentioned in your post before @1990TSIAWDTALON;)
I also made it a bit more solid than the stock one. Fits really nice now.
I will add it to the kit for just an additional $10.
Hey all,
tired of collecting all the shifter bushings you need from 5 different vendors?
Now you can get them all from ONE source!
I compiled a set of all the bushings from the complete shifter base to the shifter cables and lever arm on your transmission. All bushings were CNC machined with tighter tolerances than stock to eliminate every single shifter play on your DSM. You will feel the difference!
These will fit all 1G and 2G DSMs.
Each set will come with an installation instruction, to make the installation easy for everyone.
Sold as a complete set of 27pcs for $180!
If you don't need the complete set, no problem! Each bushing pair can also be purchased separately!
The set consists of:
1. shifter pivot bushings - back/forth (2pcs) $20
2. shifter pivot bushings - left/right (2pcs) $25
3. shifter pivot bushings - lower lever (2pcs) $20
4. shifter cable bushings - interior (4pcs) $25
5. shifter base bushings - interior (8pcs) $25
6. shifter cable bushings - transmission (2pcs) $30
7. shifter cable bracket bushings - transmission (4pcs) $20
8. shifter lever arm bushings + POM guide - transmission (3pcs) $25
And again..
Shipping is only $10 worldwide!
But due to the corona situation, it's veeery slow at the moment!
It takes somewhere between 4-8 weeks from germany because every cheap shipment will be shipped by ocean freight until further notice..
I could also offer you a much faster way with UPS within 1 week, but they charge $40 for the cheapest package.. (a group buy would pay off with this one)
So you can choose between those 2 options:
$190 shipped - USPS (1-2 months)
$220 shipped - UPS (5-8 days)
Just send me a PM with your order details and I'll get back to you asap.
Amazing! Major issues getting shifter cables for my G2 standard transmission; My speedometer doesn’t work anymore, & the small internal cog plastic piece from trans to dash speedometer (eventually) isn’t sold anywhere I have otherwise found-plus I would value help learning what that’s called, please! Keep up the stellar work, I’ll be placing orders soon for my rebuild! Aloha!
Hey all,
And again..
That looks FANTASTIC! Thank you from us all!!!!
Marty
I wanna see if this fits the short shifters or just OEM Shifter...I'm definitely interested!!!
I’m interested if they work with short shifters as well
Just had to drill a hole in the Megan short shifter for the cotter pin on the interior 2G cable bushings
This freaking awesome. Just got my 2g gsx running again and was just looking for all these! Epic! I'm getting this asap.
I finally managed to get the set ready for the 90' owners!
The pivot bushings were almost the same but with other tolerances so I had to make some new ones for that.
I also added a POM shifter stop for the 90' set that @1990TSIAWDTALON mentioned above to the kit for free.
You are AWESOME @Gsx-Dude !!!! :thumb::thumb:
How do I save this post so I can refer back to it when I am ready to order?
@OLDDOOD, "watch" the thread like my picture shows.
Ok I have to add my experience with these bushings.
I purchased a 2G set a month or so ago but did not have the time to install them until this week. All I can say is WOW!! These made a huge difference. I will attach some pics and some videos of my install, which (with some modification for my B&M shifter) only took me about 90 min to install.
Fitment is perfect, all went into place without issue. Also, they came with detailed install instructions.
The B&M shifter mounting shaft is smaller than OEM, so these bushings were a bit too thick. I used a wiz-wheel to shave down only the exterior bushing (they are soft brass so they shave down easily). Mine fit perfectly at 12.10 mm. I opted to only shave the outside bushing in order to keep the cable straight in case my grinding was not perfect. (Please excuse the mess)
STOCK BUSHINGS:
This is the movement I had on OEM transmission bushings, on a rebuilt transmission I must add...
The end result after GSX-dudes bushing install:
As you can see, there is a night and day difference!
Thank you GSX-dude for continuing to make products like this for our platform. I recommend these to anyone on here using a manual transmission.
Please support GSX-dude, every product I have purchased from him are superior-quality.
Isn't it truely amazing what a BRAND NEW SHIFTER feels like :thumb:
Hey all,
Sold as a complete set of 28pcs for $190!
9. shifter cup bushing - interior (1pc) $10
Seems like shipping slowly went back to normal and I'm able to ship these out the cheap way with regular shipping time (1-2 weeks) again.
So shipping is just an additional $10 worldwide!
do you still have this kit avail for 1g?
He was last on on Thursday. He will get back to you, so be patient. His kits are amazing (and I don't have one.......I should though).
Just letting you know.
hi, are you still offering these sets? i sent you a message weeks ago and you never responded.
Just saw that someone else messaged literally 2 minutes ago, but I'd also like to know if you're still offering these
Check the link to his site right above your questions. I just looked and he still has them listed
I like the addition of the oem-style sparkplug wire separators. I got factory ones shiped from Japan (Amayama), and I think some p/n’s showed NLA after my order. I actually think they are a good design, and seeing someone reproduce them is cool.
Hey all!
I managed to get a 1G shifter base to change all the bushings that are different from the 2G Set.
Now I can offer you the complete Set for you 1G guys too!
Number of bushings are the same, so the price remains the same.
This is the full 1G shifter bushing set
Is this still available? I desperately need a set.
