Turbo Water Line Locations
mnetwork
1,017
Feb 25, 2006
New Milford, New Jersey
I am trying to find where the other turbo water line was located on the motor and I am lost at the moment. I know where the upper one is (the one located on the water pipe itself), but where is the other line???
Im pretty sure if im clear what ## talking about the line thats right beside the radiator cap, follow that line down and there will be a line right next to it that hooks up into the turbo i believe
This is not my question. Here is an image I found online and edited...
I don't care about the turbo or how anything connects to the turbo. I am asking where is that line coming from on the engine side as I cannot find it...
It's connected directly to the block with a banjo bolt.
Yes, I realized that last night after some reading. I am having trouble finding which port actually does this. I don't have a line so it must have been blocked off, but I'd like to know which one it is. I found a plugged port in the area, but it is pretty small so i don't know if that is it.
If you still have coolant in the system, pull the plug. If coolant comes out of it you are in business.
