water line?
andytalon
277
7
Mar 27, 2005
Boston, Massachusetts
Does my 16g need the water line? I broke the banjo bolt in it :cry: :cry: and I hate banjo bolts I can never get crush washers anywhere and they just suck to work with. Anyway around this????
A easy out is a case hardened extractor that is tapered with reverse threaded grooves. you usually drill a hole in a broken bolt then screw in the extractor counter clockwise . the threads will grab the bolt and turn it out. Your banjo bolt has a hole in the center ,thread it in counter clockwise and it should back out.....Dave. Helpful? shoot me some rep points!
Easy out should work great. I had a similar problem as I broke the banjo bolt off in my head for the oil supply. Just tap the extractor in nice and easy and it should come right out. Take your time, if you break the easy out in the turbo then you're really gonna be in for some fun.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
