Turbo Upgrade help
Well someone told me on the forums that the intercooler kit i hav wont fit on the stock turbo because of the j pipe, and any links on a full fuel upgrade system?
Click the marketplace tab..You can find the fuel pump,rewire kit, afermarket fuel pressure regulator, and injectors in there..Or hit up the classifieds section for a cheap deal on these parts..
You can also find the parts from the supporting vendors alone..But I would look in the clasifieds for a deal on some of these..
I would also reccomend dsmlink, and a wideband..Once you really want to start tuning..YOu can use an safc for now,but that will only tune 70cc injectors..And is not the best tuner out there..Dsmlink is..
14b, small 16g,big16g,evo3 16g..The 16g's will be easier to get 350hp out of but you will have to run over 20 psi..Which you WILL need fuel upgrades to run that much boost on those turbo's..
Your in indiana, so I'm guessing you have e85 in the area..So you need to also decide if your going to use 91ish pump gas or e85..Your also not going to get 350hp out of 700cc injectors and an Safc..
So dsmlink Might be the best option and get it out of the way..Or evo 8 ecu and evoscan..
Here's a small list of the parts I'd recommend.
VR Speed FMIC Kit With short route piping.
16g, B16G, Evo316G all of these would be a nice upgrade.
Some larger Injectors, IE 650's-880's
255 Walbro Fuel pump Rewired
and Dsmlink v3
Done :)
and Dsmlink v3
Done :)
+2 great list..
Well i already have my FMIC, i was just trying to find a complete fuel upgrade kit, not to sound like a dumbass but i need a fuel rail, an AFPR, dont know what size injectors for sure :confused: , and a fuel pump right there isnt anyway i could buy it all at once? and i cant find a dsmlink v3 anywhere
You don't need a fuel rail, the stock one will flow plenty.
To add to Doubleot's list you'll want to add a wideband o2 sensor to that.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
