1G Turbo Options/opinions
Dstarperformance01
880
174
Mar 5, 2016
Mustang, Oklahoma
I’m trying to weigh my options on what to do about my gt35r that’s just started leaking. I’ve driven the car 3 times in the 4 months I’ve owned it and that was 3 1/2 moths ago.
I would love to upgrade to a 76mm or so but that’s going to require a different ecu set up on top of the cost of the turbo and retune as the car is currently running aem v1.
What are my options without a retune
DBB rebuild/new CHRA?
Journal bearing CHRA?
Similar sized turbo?
@JusMX141 do you have any input?
Can't rebuild ball bearing GT turbos, only replace the CHRA...Garrett doesn't sell parts for them. So you can either get a new CHRA from Garrett (anything using the 68/62mm GT35R turbine) or replace the entire turbo. Another less-expensive option would be a replacement CHRA or supercore from Pulsar but now you're putting trust into the hands of China.
There are no journal bearing CHRAs/Supercores offered which would be a direct-fit into your existing turbine housing...at least not from a quality vendor.
Not what I wanted to hear( I’m F’d) but as always I appreciate your knowledge/expertise and straight up honest answer.
Make sure it's being fed correctly and has ample drainage. These turbos need very little oil pressure / volume to survive...a head feed with a .035" restrictor in the line is adequate. Steer clear of 10AN drains if you can avoid them, although technically due to the small amount of oil they pass a 10AN should realistically work.
The inability to be serviced affordably using OEM parts is definitely a downside of a ball bearing GT turbo. Parts do exist, but 100% of them hail from China and will basically give your turbo the reliability of an eBay special once rebuilt and properly-balanced.
