Turbo oil return question?
ByrdClaw
144
Aug 21, 2007
Sacramento, California
I just recieved a pushlock oil return line for my 16g,and I wondering if I have to remove anything to make it easier? Is it a hard install with it in the car,or easy once you get the car in the air? I have been having problems with it leaking. Should I use grey silicone or the oem gaskets that came with the kit?
Ok thanks guys! I was reading about putting studs on the pan and the turbo for more torque so it doesnt leak. Do you think it will hold up just fine? I was using a poor ebay return line,and it seemed like I had to stretch it to get it to work. The pushlock line should work just fine right?
