Turbo oil return
You can try new gaskets at about $3 x 2 gaskets or you could step up to the billet return fittings and pushlock style hose. Gaskets would be cheaper but it depends on the problem
Either the gaskets are leaking or the return tube is leaking. They are easily replaced from underneath the car. THis is a common problem, especially if the exhaust down pipe is not secured to engine. On 1g there should be a bracket that holds it to engine, this is commonly removed when some one puts a different exhaust on it. If it has been removed have the exhaust shop weld up new brackets and it should stop this from happening
Telnut
I recommend Replacing the lines with Steel braided ones and replace the washers. Like said above be careful take your time. Do not make a hour job into 6 hours of runnung around looking for parts.
