Trying to tune really need help V3
SpoollinAwd
Banned Member
35
Apr 19, 2011
Austin, Texas
Ok well first off I have checked my timing Im at 5*degrees,have no boost leaks but I am still getting TONS knock can anyone take a look at my log and give your advice Thanks a bunch
P.S I use a aem uego but cant get it to log in Link :banghead:
Mods
Stock 14b
Stock Injectors
Fuel lab Afpr ,Wally 255
Fmic
Greddy Bov
Zero your fuel and timing sliders and watch this demo video ---> ECMLink Tuning Demo: Fuel Trim
That knock is obviously PK (phantom knock) because you aren't even going anywhere, just sitting in a driveway revving your engine isn't tuning the car. A few things can cause PK but most of the time its just a loose knock sensor (torque spec is 17 ft/lbs), if it feels tight though it might be bad so try replacing it.
:dsm:
I couldnt put my cruise log up but seems like most of the time its in the same place ill cut the log down and let you take a look at
First off, Corey really knows his stuff so pay attention. Second, forget about cruise logs or WOT logs until you get your idle set up right, .25 AirFlowPerRev and 0% CombindedFT's.
Make sure the knock senor is tight and also check it for goo. If you need a new knock sensor (good chance) the 1g knock sensor is part # MD141510.
$89 from JNZTuning: OEM Knock Sensor (1G DSM) : JNZ Tuning
$97 from ExtremePSI: EXTREME PSI : Your #1 Source for In Stock Performance Parts
$99 from STM: STM: 90-99 OEM MITSUBISHI ECLIPSE PARTS | DSM | 4G63
That does seem to be phantom knock. Im running v3 Speed density and whenever the car doesnt have load on it grabs knock when i rev it up quickly. I usually set my knock sensor to activate at 3000rpm and 50% throttle. I dont know if it would help or not with the phantom knock, but your fuel timing and VE tables seems like they need some smoothing out. The values are jumping a little to quickly for my liking. Post on ecmlink's forums they provide great info and are always willing to help. Other then that post a cruise log so we can see things underload.
theres a compressed cruise log thanks for all your help I have my knock settings at 3k and 40% throttle
Put a new knock sensor in old one was loose so just bought a new one.What a difference! thanks for your help
Dont know if your still tunning but you should raise your dead time till you get your global ft around 0%
