Transmission issue
Josho1
Dec 23, 2016
Cumming, Georgia
Hey guys. I just picked up a 96 Talon TSi, FWD. 120k miles. Runs great but has a transmission component issue. While running, the car will not go into gear. Slave and Master cylinder have been "replaced". The master looks new, but the slave cylinder is a little rusty lookin, BUT the bleeder valve looks new. PO said he has bled the system multiple times and will work very briefly, but eventually goes back to the same thing. I have not seen the car move, so this is just hear say at this point. The fluid is topped off and looks clean. The only thing I have done is try to adjust the rod from the pedal to the cylinder. It is twisted all the way out and I am still able to push the slave cylinder in by hand, HOWEVER! the slave cylinder does not decompress, it stays pushed in and I lose the pedal pressure until I pump it one or two times by hand. Otherwise, I can pump the clutch pedal all day, by foot, and it continues to come back.
Any thoughts?
Told you to remove the transmission.
Get all new (flywheel disc and pressure plate)
I'm glad I listened instead of selling. Why all new? Just curious. As far as the flywheel anyways. It looks like it was resurfaced recently. Pressure plate looks new.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
