transmission issue?
brandonf90
100
4
Oct 11, 2012
davenport, Iowa
i noticed my 95 GSX was not wanting to shift into higher gears under pressure and "breaking up" (throttle all the way open) when i would have it maybe 60% throttle it would shift rather well. so the other day i was driving and i noticed a strange sound coming from my transmission like a slight rubbing or a humming. so i babied it home and i realized it was sticking in 3rd gear even when i put it in L and 2. also a clunking when putting it into reverse. could it be a bad torque converter? i also noticed high temps and my tranny fluid smelling "weird".
any help on diagnosis would be greatly apreciated
Edit: ALSO it would stutter at low rpm and die "idle" then other times it would be fine
Sounds like limp mode. Plenty of posts on that and ways to fix it can be found here on tuners.
Burnt smelling trans fluid could be due to overheating, slipping clutches, clogged cooler, clogged filter. The clunk could be u joints. You really need to locate each issue, and post back. Automatic transmission issues can be fun.
i looked up some things on limp mode but that doesnt really help to get to the root of the issue of it breaking up at high rpm. (before it was going 1-4 fine when at 60% throttle). like i would have to back off the gas when fully open just for it to shift to the next gear. also the rough shift into reverse and slow shifting from Neutral to drive.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
