Transmission Cooler Questions
Avalanche419
50
Jul 7, 2007
Toledo, Ohio
After Reading About Tranny Coolers i see everyone is talking about remounting them in front of the radiator just under the bumper.....What about the Radiator Fans, like this one on ebay....<br>
http://cgi.ebay.com/ebaymotors/Dera...38172QQrdZ1QQsspagenameZWDVW#ebayphotohosting
<br>Not saying I would buy that, but wouldn't an electric fan right infront of the stock cooler work? Or what If i replace the stock cooler with an little bit bigger cooler and put the fan....that way i'm not blocking the radiator from cooling at all....is this a good idea, what do you all recommend.
Your stock Tranny cooler, is just an integrated endtank at the bottom of your Radiator.
A tranny cooler wouldn't block too much air flow if place in front of the radiator.
But if your worried about it, just mount your tranny cooler behind the driver side bumper air duct. That way it gets moving air and also doesn't block your radiator.
I wouldn't think a fan would be necessary at your point and stage. But hell, if you want to, go ahead.
Exactly what steps would you suggest in moving the tranny cooler to these places. I looked at my 95 NT and I can't put the cooler lines without cutting into the bumper support. With the other option of placing it into the air dam on the driver's side, where will you get the tubes to run from the tranny to the cooler? Please need to upgrade my cooler and any suggestions would be good.
