Oil cooler; install?
You really dont need an oil cooler for the 420a. But if your really set on getting one. Look for a factory auto trans cooler. It fits in the driver side with three bolts. so it just bolts up.
Well you need a way to feed the oil to the cooler. Most vehicles without oil coolers tend to use something called a sandwich plate. It fits between your oil filter and oil filter housing unit. This allows for a redirection of oil before or after the filter to be sent to a remote cooler.
This in combination with those oil coolers will allow you to have an aftermarket oil cooling system.
But as 97gst_spyder said, you dont really need one for the 420a.
Here is my oil cooler set up
