Jeff99GS
- 1,869
- 17
- Jun 27, 2006
Cleveland,
Ohio
Okay I am ready to install the Braided SS oil lines for my turbo 420a
I have a few Questions about doing this. The guy I bought it from said to drill and tap the oil pan and thread the bolts right to the pan to secure the oil return flange.....Is that oil pan thick enough to really get a good thread on it?? I think it needs a backing plate thats got nuts welded to it...but I'm not sure. Or can I just put nuts on it from the inside of the oil pan.... will it leak? should I just get the flange welded on? it came with a gasket, will that gasket be good enough or should I put some RTV silicone gasket maker on there to prevent leakage?
Any tips on doing these oil lines for a 420a would be great!!
I need help with the supply line too, I have been told to just T- tap off the oil gauge sending unit??? is that correct??
), and concept will give you everything you need for your oil lines for 150$ and SBR will give you all of the fittings for 65$ ( I bought mine from SBR). It was cheaper for me to go with SBR because i was able to buy the hosing from autozone for 45$ steel braided. I was going to get all my oil line stuff from home depot but i was a little leary when someone told me that there lines wouldn't withstand the kind of abuse i was going to be putting them through.
... dont act like you don't know what I'm talkin about
