2G TPS sensor wiring color
Kpro22
73
Jul 15, 2016
San Diego, California
I’m replacing the TPS sensor connector and got one on eBay and there are different colors from the factory wires . Where does the other 2 green wire match up too.
Measure resistance between the black and one of the greens. If it stays constant between 3.5k-6.5k ohms no matter where the throttle position is, then connect that green to the green-yellow harness wire. The other one should change value with the throttle position, so connect it to the brown-red harness wire.
