91-gsx
- 932
- 11
- Mar 31, 2005
San Jose,
California
It fits a 1g head. You may be thinking of the evo3 IM. I've seen "94awdcoupe" use epoxy to fill the runners to match up with a 2g head though
I did not know that the cyclone intake manifold fit 1g head intake ports, so I am sorry that I said that a stock cyclone intake manifold would not hold a candle to a stock 1g intake manifold. It should do that and better, if ported correctly.
From someone who has ran both intakes in the past month, this statement is so untrue and you have nothing but what you "believe" to rely on. If my 1g IM creamed the Cyclone up top, it would already be back on the car.
I guess what I was trying to get as is, through the statements that people have made about the stock cyclone intake manifold and the stock 1g intake manifold. I have come to the same conclusion as all of you, and that is that the stock cyclone intake manifold should be close to a 1g intake manifold in the top end, but greatly out performs it in the bottom end. But as this data shows at the bottom of this post via the G-TECH, the 1g extrude honed intake manifold shows an 11hp difference from a stock cyclone intake manifold at 7000rpm... This is where things go sour for me with this data... I have already posted a dyno graph showing a close to 70hp and 50ft/lb of torque gain at 7000rpm going to an extrude honed intake manifold.. This should be a greater difference when it comes to a 1g extrude honed intake manifold compared to a stock cyclone intake manifold.. This data does not do a properly opened up 1g intake manifold justice in my opinion, and through collected statements on this thread and others, and through the only actual dyno graph to illustrate what I am talking about.. I am not here to prove anybody wrong, I just think other options that have been proven to work should not be brushed aside with bunk data.. Some of the fastest cars on this forum and others run a 1g extrude honed intake manifold with record setting numbers and times... For example, this 16g powered car that has the highest torque and horsepower that I have seen with a mostly stock internal engine; http://www.dsmtuners.com/forums/151887256-post1.html
I am not saying he made all that power from the extrude honed 1g intake manifold, but it obviously was not holding him back with that much power and torque being created.. But we would all consider a stock intake manifold or a cyclone intake manifold, a top end dampener on the same setup..
I found some old notes the other day on cyclone. these numbers are from my 57trim turbo. the 1st column is 1g extrude honed, second is cyclone. The numbers are from g-tech which read low. On dynojet it made 411HP/410TQ at 22-23psi
RPM =1G =cyclone
4000=202=247
4500=290=292
5000=314=325
5500=341=343
6000=366=367
6500=353=351
7000=319=308
keep in mind this is against a extrude honed 1g Vs. stock unported cyclone. also the biggest gains are seen from 2500-3500rpm. I just wasnt recording numbers at those rpms. cyclone is a hell of a piece if you ask me.
but you only gain 11hp going from a cyclone to an extrude honed intake manifold, NOT PROVEN...
. The cyclone intake manifold flows as much as a 1g intake manifold uptop.
. Later.
