RipperXX
- 5,788
- 172
- Feb 23, 2003
Royston,
Georgia
I can't seem to find the video of the "new" compound turbo car. I watched it the other day and now I can't find it... Any help?
Well speak of the devil, I just got offered a working cyclone for 60bucks and even though I was looking at other intakes on the market, I thought about it for a couple seconds and say hell with it, Im trying to save some money here, so I got it. So I guess this is what Ill be running now. Its ready to bolt on and go, but I dont know what rpm the actuators will activate at this point. Im glad to hear you like yours over the 1g even with it not working properly, makes me not hesitant about using it, and also Ill have a hx40 going on when this e316g comes off - and with the extra lag of the hx40 it may be a great choice after all since Im now only looking for low 400whp.
Well what sounds like a mean street combo to me is a hx35 on a 2.3 stroker high CR motor with a cyclone intake manifold- I bet that would spool above 25psi below 3500rpm and scream all the way to 8 grand with the right cams/supporting mods, which would be nuts.
When my e316g comes off im installing a hx40 whenever i get the bolt on housing to run it. I know there will be plenty of turbo lag that I will want to make up for below 4k, so the cyclone is starting to seem more appealing with my current goals. As long as it can still pull some pretty good numbers on top end, and pull above 400awhp on pump gas then it will be worth it. I just dont want to deal with any butterfly runner issues with the cyclone, I want to put it on, and for it to work, and keep working with no maintenance, thats were the value will mainly be at for me.
The funny thing is, I actually had a cyclone not too long ago and I never got around to installing it because I didnt have the gaskets or the T25 mod to actuate it and I never put the effort in doing so, even though I should have, because it was real nice, polished and all... I ended up selling it thinking I was going to run a high end SMIM setup, but after realizing i dont need anything like that, nor want to dish out the kind of money in purchasing a good one, my goals lowered back down to Earthling levels of just having an affordable, reliable and decently quick setup. This is what re-sparked my interest in the cyclone.
...i think you see where im goin with this. hahaJMF Race manifold or the JMF Race manifold......i think you see where im goin with this. haha
But honestly I am trying to finish my car and just be content as Im trying to somewhat get out of the game. Times are looking too tough ahead to continue enduring all my cash flow into the car if you know where im going with this.A few years ago, someone did an intake manifold test. I forgot the details, but they tested a JMF, Magnus, Venom, stock, and maybe a few others. Surprisingly, the Venom was a top performer IIRC.
Goodbye stock a/t cams.
Just to update a little: I recieved the original vacuum valve for the Cyclone and still doesn't work. It worked great during testing and a first few times on the car and then stopped functioning. I'm going to go the junkyard Monday probably and grab another fpr solenoid that could be the only other thing. the actuator on intake will close when vacuum is applied just fine, Jeff O. confirmed the coding, and tried the jdm vacuum can.
Also had the water pump go bad, so a perfect time to install my HKS 264/272 cam combo i've been staring at in the garage for almost a year. Also as I had predicted, the balance shaft belt was shredded and sitting pretty close to the timing belt. I'm sure it's been like that for awhile. I'm sure I lost a little power from installing it, but its definitely smoother. I can feel an all around power gain from 4500rpm+ and it pulls effortlessly past 7k with the cams. Goodbye stock a/t cams.
^^^ That's pretty impressive results there. Does anyone have any numbers of a cyclone agains a non extrude hone intake? I'm sure extrude honing helps that 1g manifold do it's job better up top. Extrude hone cyclone, anyone?
MY opinion: I'll not call him 'Dr Turbo' until he displays highly detailed compressor or turbine theory explanation and understanding. Claiming to beat a z06 on the intarweb doesn't count.
... But i DO NOT believe it can hold a candle to even a stock 1g intake manifold at over 5000rpm.. The numbers at the bottom between the 1g extrude hone vs the cyclone at the same rpm being that close also are not justified when he made well over 400hp on real a dyno.. Also wanted to add that the G-TECH is good at calculating times and is close at guessing a quarter mile time, but they almost always have the trap speed wrong, and that is a lot when it comes to top end from intake manifolds being tested.. I am not trying to bash, I am pointing out what should be obvious.. I found some old notes the other day on cyclone. these numbers are from my 57trim turbo. the 1st column is 1g extrude honed, second is cyclone. The numbers are from g-tech which read low. On dynojet it made 411HP/410TQ at 22-23psi
RPM =1G =cyclone
4000=202=247
4500=290=292
5000=314=325
5500=341=343
6000=366=367
6500=353=351
7000=319=308
keep in mind this is against a extrude honed 1g Vs. stock unported cyclone. also the biggest gains are seen from 2500-3500rpm. I just wasnt recording numbers at those rpms. cyclone is a hell of a piece if you ask me.
Idk, the cfm difference is minoot from what I recall, I would think the cyclone would be better midrange and low end and then be similar to a stock unported 1g up top.
The 1g should only barely out perform it up top, and its not like the cyclone cant be ported out some.
I remember there was a thread here a long time ago were the guy with the white 2g gained 40ft/lbs down low from switching to the cyclone without loosing anything up top, but I dont know if he was coming from a stock 1g or 2g mani, and Ido know that he self ported his cyclone.
Well the cyclone as far as I know is made for a small intake port 2g head..
From someone who has ran both intakes in the past month, this statement is so untrue and you have nothing but what you "believe" to rely on. If my 1g IM creamed the Cyclone up top, it would already be back on the car.But i DO NOT believe it can hold a candle to even a stock 1g intake manifold at over 5000rpm
