Timing problem after head rebuild
MrGriff750
66
Jul 24, 2005
Dubuque, Iowa
I've done some research and haven't found much pertaining to my situation.
I put a rebuilt cylinder head on my 6 bolt and am having a timing problem now. The timing is far too advanced. When i retard my timing as far as the CAS will allow, it only gets down to +5, and the strange thing is it runs WORSE than it was at about +20 (estimating because its off the marks). Initially it was idling at about 1k so i adjusted the BISS so it is about 750 now, but it still runs rough no matter what the CAS has the timing adjusted to. I did all this with the ecu ground plug grounded. I double checked the Timing belt at TDC and everything still lines up.
Anyone have any ideas what could be causing this?
If you are referring to the timing marks on the crank pulley, verify the crank pulley hasn't started to slip or the rubber portion separated from the pulley. That's VERY common. Put #1 cylinder to TDC. Then check to see if the timing mark on the crank pulley is at TDC mark on the lower timing cover. If it's NOT, see if the crank pulley was installed 90* out of phase. If it was installed correctly, then the pulley has separated and it's time to replace it.
Alrite, so i put cylinder 1 at TDC and checked the timing mark's placement. It's sitting at about 0. Whats confusing me is how the pulley can go bad? Is the harmonic balancer the same as the crank pulley?
Also, i have a check engine light now too.
The timing belt is probably off a tooth on the intake cam.
Ps. To answer your previous question: The outer ring of the harmonic balancer is isolated from the center hub by a strip of rubber. They commonly slip, rendering the timing mark inaccurate.
Ha ha fixed my spelling. I had like four typos. Funny ones to boot.
This one came off my car last month:
It was only twisted enough to throw the timing marks off by a few degrees. If I hadn't noticed the rubber shreds forming during my pre-shootout checkup, it would probably still be on my car.
Here is a pic of the cam gears. This is the best pic i could get with my crappy camera phone. It's sideways, i know. I wanted to get the best shot with the dowel pins and notches.
Today i re-did the timing belt and nothing changed.
It's really hard to see anything in that photo. I like to use all four timing marks, and draw an imaginary line across the top of the head where it meets the valve cover.
Laying a straight rod across there may help you make sure it's accurate.
Yeah, the outers are always slightly higher. If the harmonic balancer is good, and the timing marks all line up, put it at TDC and then remove your cas and look at the part that goes into the slot in the cam. There will be two marks on the cas and Im willing to bet yours is 180 degrees out.
Was the cylinder head decked and resurfaced? How much was taken off? What head gasket are you running? Is it the same thickness as the previous one used? List what has changed from before the head rebuild to after the head rebuild so we can further deduce the problem.
Tim Zimmer via Evo Phone
I checked that yesterday and ran it both ways, and no change. I have it set back to normal now.
Yes it was decked and resurfaced. I don't know how much was taken off. I purchased the rebuilt head off a guy who had all the work done. I'm waiting for all the paperwork for it in the mail. I bought a Topline head gasket, and im not sure what was in there before, probably stock. I redid my vaccum lines by removing unnecessary ones and replacing the remaining ones. I put ARP head studs in. Tightened them in four steps, and in the right order.
I would measure the head deck height to find out how much was cut off. If you have too much cut off, it will affect your timing. You will either need a thicker gasket to compensate, or adjustable cam gears to get it dialed back in properly, or start over with a new head that isn't decked as much if the head is specifically the problem at hand currently.
Hmmm... I do believe that the ECU will automatically take out 7 degrees of timing if its seeing a problem with the KS, though this SHOULDNT have any effect on timing readings when adjusting base timing, because the ECU relinquishes timing control when you ground the plug...
  • Wanted 1g throttle 91 to 94 60mm
    Im looking for a working throttle body or in decent condition. Its for the 1g intake, i did a 6...
    • Josedsm
  • For sale 4G63 COP Setup ( JMFab Plate & 300m Coils )
    COP Setup $185 + shipping & paypal fees* JMFab Plate & 300m Coils * 91-99 connectorYou must...
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • For sale 2g OEM 2G Headlight Set
    OEM 2G Headlight Set $90 + shipping & paypal fees* lenses present very well * all mounting...
  • Wanted Looking for A/C parts to reinstall.
    Looking for any/all components to 97 gsx air con system.
    • Schinjon
