tattooedgst
- 0
- Jun 5, 2011
atl,
Georgia
my car was running fine untill i replaced the bearings with standard size race bearings now the car will not start unless you have your foot on the gas pedal and it will not stay running for more than 15-30 seconds if you take your foot off the pedal.Also while it is idiling on its on it has only 1-3 inches of vacuum. the vaccum will go to 10-15 if you rev the car up and take your foot off the pedal. My questions is can this be timing related.Is it possible something got out of alignment by turning the crank over by hand to replace the bearings?There are no vacuum leakes that i can find!
