Throw out bearing problem
TwinTurboDsm
May 14, 2012
Lawton, Michigan
I have a 93 laser awd turbo my clutch went out this morning so i decided to replace it. I got the flywheel and pressure plate installed. when I went to install the throw out bearing I notice it didnt fit right, then I saw part of the spline was missing please look at my pics.
Thats pretty much toast now. The tranny can be salvaged and another bell housing swapped onto it. You would have to go thru it and measure the preload on the bearings and shim it accordingly. There is probably excessive play in the gearsets causing the input shaft to wobble excessively on the end. That caused the piece to split at the end and eventually shear off the bellhousing. What did the clutch disc look like? Stock?
looked stock springs seemed very loose compared to the new one. disc was trashed because it was slipping and throwout bearing was in pieces.
IF I can find a pipe the same exat size and thickness could I have one welded on.
I found out that 2 bolts were not tight thats was caused it to break.
I ended up getting a donnor trans swapped the bellhousings.
I had that situation happen to me. I ended up machining some tubing to the original spec, welded it to a backing plate that was contoured to the bellhousing, tapped the bellhousing, used threadlock, and bolted it on. I blew that clutch up aboput 3k later. When I checked it out again, upon replacement of the clutch, it held perfect. No need to swap out the housing. This tube from mitsu's tranny is practical, but problematic if it ever breaks.
