Thoughts on Magnus 2.2 Stroker Kit??
DSM_PWR
2,457
19
Oct 12, 2007
Austin, Texas
Decided to go with the FP T4Z HTA88 Turbo because of the lag for us FWD and the amount of power it can make.
However after doing more and more research my thoughts that my 2.0 with 280 cams wont spool that turbo for a while. I wanna rev to 9k and heard that the 2.2 stoker kits alow better high revs than the 2.3+
Link to stoker kit:
Magnus Motorsports - DSM/Mitsu Engines
Never dealt with Magnus products and im sure they're great but its a pretty pricey kit seeing how the 2.3 kits go for half the price
It's also a BILLET crank, kind of ups the price for that piece. My thoughts are I want one and if / when my 1g rod / 2g piston motor bites the big one I'll be saving up for one of these beasts!
Hope you're going to be making more than 800-900hp because if not it's a waste really. That is IMO though.
Yeah like dSmgs-T said, with a GST and that hp goal, you'll have traction problems.
Get a GSX, convert yours to a GSX, or look for a goal a little lower.
Any other thoughts on this stroker?
I have this kit and about to throw them together. It is just like what you see on Magnus website. The parts consist of:
Magnus 92mm billet crank
Magnus custom aluminum rods (comes standard with L19 rod bolts)
Magnus custom Ross high compression flat-top pistons (23mm wrist pins)
Plus a few other goodies.
This exact kit with their billet knife-edge crank goes for $5000 OMG.
I didn't get their knife-edge crank (not by choice) however. The crank is still 2lbs lighter than stock but 3x stronger.
I think it is overkill for my goal. The kit alone cost more than what my car is worth. If you got the money, go for it :thumb:
Let me know if you have any more questions.
It's a waste of money, Eagle makes a 94mm crank, you can use long rods from Pauter, Oliver or Groden and get custom pistons made, and still come in at under half the price they are asking for their kit.
I dont mine paying the money,
Ive always stood behind...
"You get what you pay for right"
But these parts are well known parts as well,
More info on this build please :)
It's not like what he's telling you to do is cheaping out you would be using all good dependable name brands just without getting raped by using magnus stuff. Not that magnus stuff isn't good but if you could build a 2.2 for 1500 in parts vs 2500 I think that makes sense
But what about the rod/stroke ratio on the 94mm crank? I believe that's one of the perks of the Magnus (besides being Billet), a great rod/stroke ratio which according to them gives you a 9500rpm rev limit.
Are talking about 2.2 stroked, or destroked motor??? I've been eyeing these 2.2 destroked and they are one of the best motors around to build, but a little expensive/ I am not even talking Magnus stuff/.
Bored to 0.060 4g64 block with 94mm crank/or 92mm Magnus/, 162mm rods and custom pistons, will end you with around 2.24L of displacement. Plus you are going to have rod/stroke ratio of 1.723, higher than the 2.0 L. So you could rev it to the moon and still have extra 2.24L of displacement.
The rod/stroke ratio I mentioned is for 94mm crank.
For 92mm is 1.76. Simply divide the rod lenght you want to use, in this case-the longest 162mm rod to the desired stroke 92mm, or 94mm. The 2.0 rod/stroke ratio is 1.70.
The higher R/S ratio is, the higher you could rev the motor. Less stress on pistons and cyl. walls and more torque.
Both eagle and magnus make a 94mm crank. There is a 92mm crank too. If you going with a all out build it's not much more expensive than a regular build. You can 156mm or 162 rods stroker pistons and a 92 or 94mm crank in a 4g64 block and your set with mores displacemnet and the ability to rev high. Another thing on a 420a a 2.2 is a stroker motor when talking about 4g63/4 motors it's a destroked motor. You take a 2.4 block and turn it into a 2.2 thus the destroked.
Delta448 posted this in another 2.2 thread
The formula for displacement is 3.1415 * (bore/2)^2 * stroke * number of cylinders.
Using an 88mm (stock 2.0L) crankshaft:
85mm bore = 1997cc
85.5mm bore = 2021
86mm bore = 2045
86.5mm bore = 2068
87mm bore = 2092
87.5mm bore = 2116
88mm bore = 2141
Rod Ratios: stock piston and 150mm rod = 1.70
stroker piston and 156mm rod = 1.77
stroker piston, 2.4 block, 162mm rod = 1.84
For a 92mm Magnus crankshaft:
85mm bore = 2088cc
85.5mm bore = 2113
86mm bore = 2138
86.5mm bore = 2163
87mm bore = 2188
87.5mm bore = 2213
88mm bore = 2238
Rod Ratios: stock piston, 148mm rod = 1.61
stroker piston, 154mm rod = 1.67
stroker piston, 2.4 block, 160mm rod = 1.74
For a 94mm Eagle crankshaft:
85mm bore = 2134cc
85.5mm bore = 2159
86mm bore = 2184
86.5mm bore = 2209
87mm bore = 2235
87.5mm bore = 2261
88mm bore = 2287
Rod Ratios: stock piston, 147mm rod = 1.56
stroker piston, 153mm rod = 1.63
stroker piston, 2.4 block, 159mm rod = 1.69
For a 97mm Crower crankshaft:
85mm bore = 2202cc
85.5mm bore = 2228
86mm bore = 2254
86.5mm bore = 2280
87mm bore = 2306
87.5mm bore = 2333
88mm bore = 2360
Rod Ratios: stock piston, 145.5mm rod = 1.5
stroker piston, 151.5mm rod = 1.56
stroker piston, 2.4 block, 157.5mm rod = 1.62
For a 100mm (stock 2.4L) crankshaft:
85mm bore = 2270cc
85.5mm bore = 2296
86mm bore = 2323
86.5mm bore = 2350
87mm bore = 2378
87.5mm bore = 2405
88mm bore = 2433
Rod Ratios: stock pistons, 144mm rod = 1.44
stroker pistons, 150mm rod = 1.50
stroker pistons, 2.4 block, 156mm rod = 1.56
For a 102mm Crower crankshaft:
85mm bore = 2315cc
85.5mm bore = 2342
86mm bore = 2370
86.5mm bore = 2397
87mm bore = 2425
87.5mm bore = 2453
88mm bore = 2481
Rod Ratios: stock piston, 143mm rod = 1.40
stroker piston, 149mm rod = 1.46
stroker piston, 2.4 block, 155mm rod = 1.52
For a 106mm Crower crankshaft:
Crower states the 106mm crank must be used in a 2.4L block, stock 2.4L bore is 86.5mm.
85mm bore = n/a
85.5mm bore = n/a
86mm bore = n/a
86.5mm bore = 2491cc
87mm bore = 2520
87.5mm bore = 2549
88mm bore = 2579
Rod Ratios: stock piston, 2.4 block, 147mm rod = 1.39
stroker piston, 2.4 block, 153mm rod = 1.44
I talked to Marco and it can be achieved different ways. I'm going with the 4g63 block because they are easier to find. I believed you can achieve ~2.24L with 4g63 block, 92mm crank, 150mm rods and custom pistons. This is the exact combination I went with after talking with Marco. We will see how my build going to come together in the next few months.
So you're saying 92mm would give the best R/S ratio? What is the R/S for 2.3/2.4L? Magnus advertised 2.2L would give a broad flat torque curve and able to take it to 9500rpm. I'm curious how this would compare to a 2.1L and 2.3L torque curves.
The best-highest R/S ratio is found in 2.1 destroked 1.84. You can calculate R/S ratio by dividing rod lenght to stroke, in any combo of rods,cranks pistons. As I mentioned above the highest R/S ratio is, the better for reasons I mentioned too.
As Slippi84 mentioned above some of this good info we got, after talking to a member here: delta 448. He knows a lot on this matter.
I agree with GVR4592 and Slippi, you always 'pay for what you get', not neccesarily 'get what you pay for'. Research a $1500-2500 investment, like you are, and you'll see that many of these companies charge you more because they make the choice for you so that you can be mindlessly dumped into a fast setup. A little research and you can save literally thousands of dollars. Magnus is a great company and Marco has the experience to win you alot of races, but what have others done, too? What else is out there should be asked for all your preferences? Imagine what you can do with an extra few thousand you saved by being a smart consumer, not a trusting buyer.
