New engine build 2.2 stroker
Tom N
Supporting Member
414
32
Sep 27, 2002
Sarasota, Florida
The engine in my evo 1 crankwalked so i am building a new one for it.
I have always done high compression 2.0ltr engines before and decided to try something new this time. I am sticking with the 7 bolt.
Going to give the 2.2 a try.
I gathered a list of parts i am going to go with.
Using a 2.0ltr block.
Eagle 94mm crank
Manley 156mm 7 bolt rods part number 14020-4
Manley 2.1ltr 10:1 86mm pistons part number 619210C-4
This should give me a displacement of 2184cc and a rod ratio of 1.659 in a 2.0l block.
I would really like to go with 86.5mm pistons as it would give me 2209cc which would be a actual 2.2ltr but i`m not sure about boring it out that much.
Anyone else here done a 2.2 stroker?
Any reason why I cant bore the block out to 86.5mm?
What is the most people bore these blocks to with out using block filler.
This car will never be a drag only car and i dont see it ever being more than a 500-550hp car.
I just had my Magnus 2.2 done but havn't had a chance to try it yet. 156mm rods are pretty long for the 2.0 block. Pretty sure Manley sells a 2.2 rotating kit.
Yes they do. You have a choice of 150mm rods with matching pistons or 156mm rods with matching pistons. I am not interested in the rod ratio of the 94mm crank with 150mm rods. The 156mm rods give me a rod ratio that is very close to a factory 2.0l.
Also the only manley 94mm crank is one thats over $1000. I do not need more than the eagle forged crank for a 500hp car.
Just curious, but why all the trouble and expense for a car not intended to be above 550HP? You could do a stock block with EVO or even stock pistons/rods to support that power. Another option is to use a 4G64 block and 4G63 crank and keep a good rod ratio. Are you looking for solely top-end power?
"I just want to try it" is a perfectly legitimate answer, I'm just curious about the application behind the build!
Block and crank are ruined from crankwalk. I have to tear the whole thing apart and build a new motor and its not much more to just used forged parts plus I like 10:1 motors. Not really looking to walk a fine line trying to keep a stock motor together at 500-550hp also. EVO 3 pistons are 9:1 which is nice but its not 10:1 and they are known to crack.
So since I have decided I am building a fresh motor with forged internals I decided to simply try something different for me. I am not interested in 2.4 block as I already have everything minus crank, pistons and rods for a 2.0 7 bolt.
I thought the option for 156mm with Manley was for the 4G64 block. I have the 92mm crank with 150mm rods and wrist pins are moved up 3mm I believe while the stroker pistons are moved 6mm. In a 4G63 block thats going to be some super short piston skirts.
The skirt doesn't have to be short, but the compression height sure will be though. -Should be somewhere around a couple of cunthairs over an inch from pin center to crown on that combo, -and then take another 8-17cc's out of the top (depending on comp ratio desired) and the piston ought to be preeeetttty lightweight... :hmm:
I plan to use 10:1 pistons.
I'm hoping this set up will work out well.
Displacement closer to a 2.3 with a rod ratio close to a 2.0
  • Wanted 6 bolt NT water pipe
    • chrisman287
