This keeps happeneing...
Doug Mercer
53
Jul 1, 2010
Courtenay, BC, Canada
:banghead:I have a rebuilt 4g63 and i kept my old transmission. My tcase was pooched so i found a new one I put it on without counting the splines. and it was a 23 and i need a 22.. so it made a god aweful slipping noise. I ordered a 22 spline tcase, just came yesterday. I put that on and soon enough. It made the same gros grinding sound. When the tcase was off the car was running like a top and the clutch was good too. But now whenever I push in my clutch the idle dips and makes a noise like the clutch is wobbling around. I am really frustrated now becuase I've had my car off the road for 3 months now for what should have been a week for an engine and tcase swap. HELP ME OUT
Did you check the splines on the input shaft for damage? Especially being that you somehow managed to get a 23 spline in a 22 spline.
no i didnt im lookin for one now... It was a stupid mistake.. a newb mistake i know.... would a center shaft from a 95 work?
Check the shaft, and check your transfer cases for a circular cut right behind the output sleeve (where it mates with the shaft). Search through my past threads to find pictures of what I'm talking about. If you see something like that, it means you're missing transmission mounting bolts.
I never heard that sound, speculating the damage was done before I bought it. But I do imagine it would make a very similar noise.
Hey man i looked at your other threads and I know my tranny mount is not tightened all the way. And i think tcases are 5 bolts? and i only have 4 in... would this ### that much change?
Transfer cases are supposed to have five bolts. Having one missing may contribute to the problem, since I also had one missing. The white lines on this picture show where they should be.
Tightening the tranny mount to spec shouldn't hurt... actually, that's probably your problem if it's loose enough to let it hang too low by just a little bit. But I was referring to the bolts holding it to the block. Those are known to disappear for a variety of reasons, and major damage can result. Not going to completely spoon feed you on that one though, go look on the VFAQ site for their sizes and locations.
If your RPMs drop when you press the clutch in and you hear a grinding sound, grinding is taking place. The transmission, transfer case, and starter are all allowed to move in, out, up, down, and all around when everything isn't secure.
yup my rpms drop alot and it almost dies it makes a hard rubbing noise not a grinding but i can feel a lot of resistance
I took a look at m y tran bolts. 2 disapeard! WTH the small one on the bottom left and one on the top left are gone.. and the other two are loose. i can put my pinky in underneath the tran into the bellhousing
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
