Shaft keeps popping out
CheapTalon
52
3
Oct 17, 2004
Grand Rapids, Michigan
When i bought my 1995 AWD talon (5spd) it had a bad wheel bearing. As with most 2g's the cv shaft was frozen in the knuckle. So I bought a new wheel bearing and knuckle from the dealership, and a new cv shaft from NAPA. After installing all of this I drove it around the block a few times and it rode great. I was dumb and launched it a couple times and got on it a little, but nothing too harsh cause I didn't want to break it. Well, no such luck. It seemed to have a bad clutch. It would still move but as soon as i tried to give it any power, RPMs rose and car would continue going same speed. So I figured #### it, and put in a new clutch since this one had 110k on it and prolly needed a new one anyway.
Skip ahead a couple weeks and I finally got the clutch put in and drove it around the block a few times (being very easy to break it in) and it rode perfect again. Pedal needed to be adjusted, but it still worked fine so I decided that I would drive it to work. Drove fine for about 2 miles till the highway, still good for about 10 more miles on the highway (didn't really get on it to pass anybody) and when I got off to 28th street and tried to take off from the light it did the same thing it would before I put the clutch in. I could take off and feel that it engaged a little "easy" and when I tried to give it any throttle it would slip. So I limped it like a mile or two to work and thought about it all day long. I just figured that I would limp it to my buddys house which was just a few miles away and make sure not to get on it so that it wouldnt' slip and ruin the new clutch.
Well once I got it to his house we jacked it up and fluid started leaking all over the ground. Seems that the new cv shaft that I had put in (pass side, shorter shaft) popped out. I was like ::whew:: easy fix. So I popped it back in and went on my way back home. I drove about 1/4 mile down the road, still in, and turned left and car drove fine. Got up to 55mph and drove for about 2 more miles and when I came to a stop sign and tried to take off, same dang thing. Limped it back to friends house to find that it popped out again. Stretched out snap ring on the end of the shaft (thinking maybe that just wasn't tight enough), popped it back in and after same drive distance as last I pulled a U'ey and felt that it popped out again. Now it just sits at his house and I have no idea what would make it do this. After thinking about it, clutch wasn't needed after all, shaft just had popped out while i was driving it and that made it feel like it was "slipping". I did a search and found nothing. Shaft doesn't just pop out with ease after we slid it in, had to pop it out with a pry bar to get it out again.
So now im stuck and don't know what to do. DSM gurus your help would be greatly appreciated. Thank you.
You messed up the seal on the tranny side of the shaft :(
You will have to yank it all back out to replace it. Im not sure how much you have to dismantle to change that. But, it WILL have to be done. CV wise you probubly messed up the sirclip (snap ringy thing) on the end of the axle and it too will need replaced. Did you tq down your castlenut on the end and use a carter key?
Sounds to me like that fluid is getting on your clutch somehow from the blown seal
good luck
He said it was leaking because it popped out not because the seal is bad. I work in a shop and it sounds like you got the wrong cv axle. It's not that uncommon it's probably just a little bit shorter than your old one. One bad thing is you don't have your old one to compare it to, but I would go back to where you bought it from and tell them what is going on and get a new one.
I figured it might have to do with the shaft. I had a lot of trouble with NAPA and getting the right one. I think what i will do is just get one from a different store and then if thats right just return the one that i have now. Thanks for the help :talon: .
If you pull out the CVs, NOTHING should leak out. If there is fluid coming out when the CV is removed the seal is damaged. Read a haynes manual or rip some out yourself. Yes, I have also seen cases of the wrong axles, but they break shit when it pops out. Like the entire tranny around the cv or it could damage the seal. This also wouldnt justify the clutch problem either :cool:
btw... im not arguing the fact that the car may very well have the wrong axles... but that seal is toast ;)
I think that at this point I will just try installing another axle shaft. And as far as I know, every transmission (or at least everyone Ive ever worked on or seen) leaks fluid when the shaft is taken out. Thats why they make those plugs so that you can plug the hole when doing a cv shaft replacement without losing all the fluid. Hopefully this fixes it, thanks for all your help.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
