Clutch keeps blowing
dsmornothing
603
11
Jul 23, 2009
Ishpeming, Michigan
Alright so in the past 3 months i have blown 3 clutches. the first one was a ACT 2600 and after 10000 miles i blew the springs out of it. i replaced it with a fidanza 3.2 and 300 miles later boom it blows apart again. I replaced it yet again with another 3.2 and 800 miles late boom again, this time starting it up in my driveway. What keeps happening is the center hub that holds the springs in keeps blowing apart. Do you have any ideas? This is driving me absolutely nuts!:banghead:
Have you tried to contact Fidanza with your isses? I just got the RGA# to send my clutch to them.
Everything is lining up perfect when you install? How about the transmission dowel pins, they lining up and/or in?
yes i have contacted fidanza again. everything is lining up good when it goes back together. i just dont know what to think? maybe my flywheel was stepped wrong?
was the FW resurfaced for each new clutch im sure it was after the ACT and 10k miles aint too bad for a clutch depending on your driving
I have had the same thing happen. Turns out my input shaft was a little bent and it wasnt going straight into the splines when bolted to the block. It would either blow the torsion springs right out or seperate the friction from the metal. I replaced mine 3 times double checking everything but that.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
