2G Think I’m missing a ground? Not sure what it goes to?
ncarson91
138
19
Jan 2, 2021
north olmsted, Ohio
Hello of anyone could give me some input I believe I am missing a ground that attaches to my intake manifold on my 2g gst here’s a pic of where I think it should go? Unsure what it goes to or what goes there. It’s the threaded hole next to sensor
nope, not for a ground. hope this pic helps
definately helps tysm! but what might go there i see something is bolted in there it looks like that flat metal piece with rubber casing. do i need that? or can i just thread a bolt in to cover the hole? sry super new to everything
That's black plastic, actually. There's supposed to be a tab from the harness that runs across the front of the intake manifold. That tab is supposed to bolt there. If it's not there, it's not the end of the world, the car should still operate as intended. As well, you don't need to plug the hole - it's not going through the manifold.
