Doubleot
- 2,142
- 384
- Mar 15, 2009
Spanish Fork,
Utah
Thats intense. Can't believe you actually brought it back.
I think its important to mention most people think .0012 when you say 12 thousandths. He took .012 off, thats a hole different ball game of material taken off
Lucky you, with this guy working on cars, he should keep you in business.
Haha I guess we now achieved a piston sticking out of the deck.
, my 7mge (toyota supra motor) is actually a positive deck piston motor. i believe after milling, my pistons sit .024" above deck (stock is .020).twelve thousandths = 0.0012twelve thousandths = .012
twelve ten-thousands= .0012
.10 one tenths of an inch
0.010 one hundred of an inch
0.001 one thousandths of an inch
twelve ten thousandths (which is incorrect anyways)= 0.0120
No that is 12 thousandths
correct. and 1/10 of 1000 is 100. so .100 is one hundred thousandths.
correct, but machinists use thousands, so that is ten thousandths.
correct
correct. and the last one is one ten thousandtheither way I hate trying to talk about thousandths and its positioning, it hurts my head
no wait I just read your numbers, im sure thats wrong, 0.010 is not ten thousandths of an inch its ten hundredths of an inch, meaning it will take 100 0f 0.010 to make an inch, if you use ten thousandths as 0.010 you would have to multiply 0.010 ten thousand times, which gives you:100 inches not 1 inch which is the global standard.
ten thousandths of an inch would be 0.0001 which is immeasurable physically.
1 inch x 1 = 1.0
0.10 one tenth, x 10 = 1.0
0.01 one hundredths, x 100 = 1.0
0.001 one thousandths , x 1000= 1.0
0.0001 one ??? My brain is fried at this point because I dont know what to call this. someone help
... as a math major seeing this.... hahahah
. Since inches ARE a unit, technically this could be correct.
WTF... as a math major seeing this.... hahahah
just keep it simple let the calculator figure it out for ya
1 hundredth = 1/100 = .01 = ten thousandths (.010) = a hundred ten-thousandths (.0100). They do not simplify or equal each other in the real world, (only on paper they are =) because you are talking about significant digits, or precision, usually dictated by the measuring device.
the first number is the top (numerator) and the second, (the ----ths #) is the bottom. divide and whala, no more confusion.
The beauty of the metric system is that that ugly 1/10,000 -or- .0001 is simply "100 micrometers" I suppose you could always adapt English units, milli-inches, microinches. one ten thousandth inch becomes 100 micro-inches. Since inches ARE a unit, technically this could be correct.
WTF
