1991 Eagle Talon TSi AWD
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
16g
Drivetrain
AWD
Build Type
  1. Street
Intake:
~24"x12"x3" Front Mount Intercooler
~Custom 2.5" Intercooler piping
~Vibrant Silicone couplers
~T-Bolt clamps
~3" Cold Air Intake with K&N cone filter
~Stock BOV DodgeGarage modified w/ Ecmlink control
Exhaust:
~2g Exhaust manifold ported
~MHI Big16g ported
~Stainless Steel o2 housing
~Full 3 inch catless exhaust
Fuel:
~Fuel Injector Clinic 1120cc injectors
~340lph Stealth Aeromotive fuel pump rewired
~Aeromotive FPR 43.5 psi base pressure
~STM -6AN pump to rail fuel line
~Fuel pump rewire
Cooling:
~Aluminium radiator
~Aluminium shroud
~Slimline 12" fans
~Gates coolant hoses
Misc:
~Vibrant Oil catch can
~Battery to the trunk rewire
Body FX:
~Custom projector housings and HID 6000k
~Subaru RS front bumper
~Z3 front fenders
Carbon Fibre Pieces:
~Carbon Fibre rear centerpiece
~Carbon Fibre gauge bezel
~Carbon Fibre Shift knob
~Carbon Fibre Shift boot
~Carbon Fibre eBrake Handle
~Carbon Fibre fuel door
~Carbon Fibre vinyl on interior trim and arm rest
Mods-Engine
7.8:1 pistons
Balance shaft elimination
Custom 2.5" Intake elbow on throttle body
3g valve lash adjusters
ARP Head studs 100ftlb
OEM Mitsubishi MLS Headgasket
Decked block
Shaved head
Oil pressure relief valve porting
Oil to head porting
Gates timing belt
ACL Race Bearings
Rebuilt short block & head
Mods-EMS & Logging
Ecmlink v3 Full
OmniPower 4 bar MAP sensor
GM Intake Air Temperature sensor
3" GM MAF sensor
Innovate LC-1 wideband
Autometer C2 gauges
Pyrometer
Boost gauge
Oil pressure
Water temp
Voltmeter
Fuel pressure sender to Ecmlink input
Mods-Drivetrain
SHEP RACEING stage II AWD tranny with EVO III 1st gear
6 bolt Fidanza aluminium flywheel
2200lb Gripforce pressure plate
Gripforce Kevlar clutch
Short shifter
New pivot ball
New fork
New Clutch Master cylinder
New Clutch Slave cylinder
Welded clutch pedal assembly
Stainless Steel clutch line
Rebuilt driveshaft with new carrier bearings
4 Bolt rear LSD
8"+9" Brake Booster from 1g Galant
2g Big brake upgrade
Stainless Steel brake lines
Crossdrilled & Slotted rotors
Full Energy Suspension bushing kit installed
Complete underbody restoration and rubber undercoating
All new OEM underbody and suspension nuts and bolts
TEIN SS coilovers
Ingall's rear camber arms
rear subframe bushings
Parts Wishlist
Rebuilt transfer case.
Background
I was into building Dodge Colts and then i was offered this Talon from a guy at the drag strip. I bought it for $1200 and it had a blown motor. I towed it home and started learning about Talons. I've had alot of trial and error with this car and i finally have a decent setup for reliability and power.
1/8 Mile E/T
8.600
1/8 Mile MPH
96.400
Dyno HP
400 whp
430 lb/ft
Dyno Session Details
this is a dsmlink estimate.
  • Like
Reactions: FAQGSX222
EGLTAWLN
Rating
5.00 star(s) 1 ratings
More in 1G DSM
Share this Vehicle
