keltalon
Supporting VIP
- 3,476
- 966
- Jun 29, 2003
Luthersville Ga, Atlanta,
Georgia
You want to know what cams are best for your setup, exhaustively test them all, then you can say that on this setup xx cam is better. But you still cannot make a statement that xx cam is better than yy cam by looking at the specs.
Bastard I need to get your real name its just something about typing bastard when responding
But at any rate I feel the same way about finding the right cam for your set up. Cams are important but as you stated before its just too many variables to take into consideration, no two engines are built exactly with the same specs, clearances, turbo sized, manifolds, exhaust systems ect. Therefore a cam that is right for my setup might not be right for the next man. But, if the next man wants to get as close to my set-up in part for part then he can maybe start with the cam I am using and them go from there. I am a woodworker and never claimed to be a guru in building these engines , I am self taught and to some seem to have a caveman approach to how I do things but none the less I get results and have wowed the gurus locally with the power the car puts out.
Okay getting back to the cams I have personally found the specs listed by cams makers to be the standard and although ,according to dub are not accurate based on a can analyzer, nonetheless still to be a good indicator in lift and duration to putting the masses in right direction as to what cam to run and many have had much success with these standard. When putting together my set up I matched my cams, head flow, and intake manifold together in hopes of getting the righ combination and IMO I think I did a satisfactory job but it took a lot of thinking on my part.
The first thing I needed was to find out what my head was flowing on a flow bench. Then this gave me an idea of how this head and the bc272 would react together. Although I didn't have a means of testing the manifold I knew it needed a little help therefore I ported the heck out of it, took forever, then I put the biggest throttle body the cyclone would take, s90 70mm cyclone modified to the throttle opening 5 to 6mm increase and all worked perfect with the smaller bc 272 cams. below is my head flow sheet. the red and green lines are after porting the head.. the flow started to choke on intake side above .450 lift but was corrected with the porting. big difference also in the exhaust flow and valve velocity. As you can see the head with a different intake and slightly larger cam will show some more improvement in power and that my friend is where the jmf street and a set of 276bc will hopefully match the head flowing capacity a little better I am still waiting on stuff to get here.
